.flv file occur number format exception.
darkerthanblack
Post by darkerthanblack »
05-06 18:20:27 null
java.lang.NumberFormatException: For input string: "29.970 / 29.970"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1222) ~[na:1.6.0_65]
at java.lang.Double.parseDouble(Double.java:510) ~[na:1.6.0_65]
at net.pms.dlna.DLNAMediaInfo.getValidFps(DLNAMediaInfo.java:1353) ~[ums-3.6.0.jar:na]
at net.pms.encoders.FFMpegVideo.launchTranscode(FFMpegVideo.java:815) [ums-3.6.0.jar:na]
at net.pms.dlna.DLNAResource.getInputStream(DLNAResource.java:2420) [ums-3.6.0.jar:na]
at net.pms.network.RequestV2.answer(RequestV2.java:350) [ums-3.6.0.jar:na]
at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:288) [ums-3.6.0.jar:na]
at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:246) [ums-3.6.0.jar:na]
at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:318) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [netty-3.9.0.Final.jar:na]
at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [netty-3.9.0.Final.jar:na]
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895) [na:1.6.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918) [na:1.6.0_65]
at java.lang.Thread.run(Thread.java:695) [na:1.6.0_65]
05-06 18:20:27 null
at net.pms.encoders.FFMpegVideo.launchTranscode(FFMpegVideo.java:816) [ums-3.6.0.jar:na]
few of flv movie files are only playable and almost flvs occur that exception messages.
darkerthanblack
Re: .flv file occur number format exception.
On UMS 3.6.1, this is fixed.
Thanks.
darkerthanblack
The problem have returned again in 3.6.4.
Optimus_prime
Post by Optimus_prime »
Thats strange, i'll have a look at the changes between 3.6.1 and 3.6.4
Also did the other versions work in between, like 3.6.2 or 3.6.3?
