UMS 3.6.0 and Philips Aurea issues
IL2
Post by IL2 »
Since 3.4.0 release I'm experiencing these issues:
  1. ffmpeg is used by default even if mencoder selected or ffmpeg is disabled and unsuccessfully
    ums_dbg2.zip
    ffmpeg error
    (16.61 KiB) Downloaded 501 times
    [pool-12-thread-2] Starting "C:\Program Files\Universal Media Server\win32\ffmpeg.exe" -loglevel fatal -ss 0 -i "G:\ums\Spring Parade.avi" -an -an -an -an -an -an -an -an -an
    [pool-12-thread-2] Attaching thread: ffmpeg.exe-2
    [ffmpeg.exe-2-2] At least one output file must be specified
    [ffmpeg.exe-2-Cleanup] Stopping process: ffmpeg.exe-2
  2. chapters are not generated in 3.4.0+ at all, they are good in 3.3.0
    ums_dbg4.zip
    java exception
    (33.74 KiB) Downloaded 567 times
    probably it is this exception:
    ERROR 2014-05-07 08:11:13.878 [New I/O worker #7] Error adding child: "Spring Parade.avi"
    	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:726) [ums.jar:3.6.0]
    	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:479) [ums.jar:3.6.0]
    	at net.pms.dlna.MapFile.manageFile(MapFile.java:116) [ums.jar:3.6.0]
    	at net.pms.dlna.MapFile.analyzeChildren(MapFile.java:169) [ums.jar:3.6.0]
    	at net.pms.dlna.DLNAResource.discoverWithRenderer(DLNAResource.java:973) [ums.jar:3.6.0]
    	at net.pms.dlna.DLNAResource.getDLNAResources(DLNAResource.java:889) [ums.jar:3.6.0]
    	at net.pms.network.RequestV2.answer(RequestV2.java:654) [ums.jar:3.6.0]
    	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:288) [ums.jar:3.6.0]
    	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:246) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [ums.jar:3.6.0]
    	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) [ums.jar:3.6.0]
    	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) [ums.jar:3.6.0]
    	at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) [ums.jar:3.6.0]
    	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) [ums.jar:3.6.0]
    	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:318) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [ums.jar:3.6.0]
    	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [ums.jar:3.6.0]
    	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [ums.jar:3.6.0]
    	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [ums.jar:3.6.0]
    	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_55]
    	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_55]
    	at java.lang.Thread.run(Unknown Source) [na:1.7.0_55]
IL2
Re: UMS 3.6.0 and Philips Aurea issues
Post by IL2 »
Well, chapters are generated and played once after clean reinstall, however java exception is still there
ums_dbg6.zip
java exception #2
(43.87 KiB) Downloaded 537 times
One thing about recently played files I don't understand, why the file some times gets removed from its folder on the TV interface.
There were problems resuming video from both #transcode and recently played folder both in ums_dbg6.zip and
ums_dbg5.zip
resuming error
(47.09 KiB) Downloaded 586 times
If you played chapters once, they also are added into recently played folder in the form >>[05:00:00] and Resume:>>[05:00:00] along with original filename, but chapters resuming is not saved between restarts.
There are many same titles of the movie in the recently played folder in the form: "Movie Name [Mencoder]" and "Resume:Movie Name [Mencoder]"
data1.zip
UMS data folder
(1.02 KiB) Downloaded 515 times
STR:
1) start playing movie, stop it
2) go to chapters, play from [05:00:00], stop it
3) now you may not see original file in its folder (well, sometimes)
4) go to recently played folder and start resuming one by one
5) the 1st resume may work (even if it is Resume:>>[05:00:00]) yet the others sometimes don't work
6) at this step chapters are not generated
Btw, it might be useful to add data folder when packing debug files.
