Implement CORS
Implement CORS
There are some clients that will not connect to a server that does not implement CORS. Implementation is actually really simple. It only requires that when a client sends a request to UMS you would need to return a couple more response headers. Namely Access-Control-Allow-Origin and Access-Control-Allow-Headers. It should be a simple change and will open up quite a few new avenues of development. I'm sure the Web-based client that has been in development would benefit greatly from this as well.
Re: Implement CORS
Can you provide any reference documentation?
Universal Media Server Wiki!
Re: Implement CORS
Basically you just add the headers Einzeln cited in each Web Player response (I'm assuming this occurs only with Web Player). More information in this Wikipedia article:
http://en.wikipedia.org/wiki/Cross-orig ... ce_sharing
- SharkHunter
- Developer
Re: Implement CORS
Which types of clients? Only WEB clients or even UPNP/DLNA once?
Re: Implement CORS
Unrelated to this particular question, but 'Access-Control-Allow-Origin="*"' is already sent by the push handler in the upnp branch so the player can communicate with UMS from other domains. I'm also curious to know specifics of 'some clients'.
- SharkHunter
- Developer
Re: Implement CORS
That's why I askedinfidel wrote:Unrelated to this particular question, but 'Access-Control-Allow-Origin="*"' is already sent by the push handler in the upnp branch so the player can communicate with UMS from other domains. I'm also curious to know specifics of 'some clients'.
Re: Implement CORS
Well, I actually can't speak to just how many clients might require CORS, but my specific situation was that I was fiddling with javascript in an html page I wrote to make xmlHttpRequest calls to ums from my chrome browser. I had issues at first because the 'chrome browser' specifically, requires CORS implementation from the server to make calls to other domains as infidel stated. I actually got around this by using a chrome extension called Allow-Control-Allow-Origin that listens for responses and fools chrome by appending Access-Control-Allow-Origin to the response. Then I modified that extension into a second extension that I call Allow-Control-Allow-Headers to append Access-Control-Allow-Headers to the POST request responses. Anyway all that info was a little unnecessary but all-together I was able to retrieve and store the responses after fooling chrome. I imagine some of this is along the same lines as what you guys are trying to achieve with the web ui.
