directv hr34/700 "x" next to some videos
Recently upgraded from Windows xp to windows 7. Ran UMS on the XP computer for several years (not sure which version of UMS I had last though) with no problems. ALL my movies would play. After installing UMS 3.6.2 for the first time in Windows 7 most movies have an "X" in front of them. Now I say ALL but I didn't watch ALL of them through UMS, but what I really mean I guess is that they had the videocamera icon not an "x".
At first it seemed movies encoded with dvdfab played and those encoded with handbrake didn't. But looking further I have to movies both encoded with dvdfab and one will play and one won't.
This is the mediainfo for 3 files. The first "after Earth" (dvdfab) will play fine. "Ahh zombie" (handbrake) will not. "all is bright" (dvdfab) will not play. By not play I mean has an "x" next to the name and when clicked on will just bring you back to the "my computer" selection screen on the HR34/700 menu system.
I also have a brite-view meadia streamer which I set to connect to UMS and it did play "ahh zombie".
Not sure what else to provide. Logs can be provided but not sure what "level" would be needed also would the log show that files are not shown as playable on the HD34's side????
Danneauxs
Complete name : H:\Movie_Database\_ Newest Movies\After Earth.mkv
Format : Matroska
Format version : Version 2
File size : 660 MiB
Duration : 1h 40mn
Overall bit rate : 921 Kbps
Movie name : After Earth
Encoded date : UTC 2013-10-25 15:44:57
Writing application : DVDFab
Writing library : libebml v0.7.8 + libmatroska v0.8.1
Video
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 40mn
Bit rate : 775 Kbps
Width : 720 pixels
Height : 306 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.147
Stream size : 555 MiB (84%)
Writing library : x264 core
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 40mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 91.7 MiB (14%)
Language : English
Default : Yes
Forced : No
Text
Format : VobSub
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:(01)00:00:00:000
00:08:52.000 : en:(02)00:08:52:000
00:15:35.000 : en:(03)00:15:35:000
00:21:34.000 : en:(04)00:21:34:000
00:30:48.000 : en:(05)00:30:48:000
00:36:43.000 : en:(06)00:36:43:000
00:41:11.000 : en:(07)00:41:11:000
00:47:02.000 : en:(08)00:47:02:000
00:52:31.000 : en:(09)00:52:31:000
00:59:42.000 : en:(10)00:59:42:000
01:05:19.000 : en:(11)01:05:19:000
01:11:02.000 : en:(12)01:11:02:000
01:15:39.000 : en:(13)01:15:39:000
01:20:09.000 : en:(14)01:20:09:000
01:24:29.000 : en:(15)01:24:29:000
01:29:03.000 : en:(16)01:29:03:000
________________________________________________________________________________________________
Complete name : H:\Movie_Database\_ Newest Movies\AHH Zombies.mkv
Format : Matroska
File size : 654 MiB
Duration : 1h 31mn
Overall bit rate : 1 003 Kbps
Writing application : HandBrake 0.9.6
Writing library : libmkv 0.6.5
Video
Format : AVC
Format settings, ReFrames : 4 frames
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 1h 31mn
Sampling rate : 48.0 KHz
Default : Yes
Forced : No
Menu
00:00:00.000 : Chapter 1
00:16:38.998 : Chapter 2
00:31:34.893 : Chapter 3
00:48:02.379 : Chapter 4
00:58:31.007 : Chapter 5
01:14:03.939 : Chapter 6
01:31:11.466 : Chapter 7
___________________________________________________________________________________________________
Complete name : H:\Movie_Database\_ Newest Movies\All is Bright.mkv
Format : Matroska
File size : 708 MiB
Duration : 1h 47mn
Movie name : All is Bright
Encoded date : UTC 2013-12-21 19:02:33
Video
Format : AVC
Duration : 1h 47mn
Bit rate : 775 Kbps
Width : 720 pixels
Height : 304 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.148
Stream size : 595 MiB (84%)
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1h 47mn
Bit rate : 128 Kbps
Bit depth : 16 bits
Stream size : 98.4 MiB (14%)
Language : English
Default : Yes
Forced : No
Text
Format : VobSub
Codec ID : S_VOBSUB
Language : English
Default : Yes
Forced : No
Menu
00:04:09.000 : en:(02)00:04:09:000
00:12:23.000 : en:(03)00:12:23:000
00:18:47.000 : en:(04)00:18:47:000
00:27:03.000 : en:(05)00:27:03:000
00:36:01.000 : en:(06)00:36:01:000
00:41:08.000 : en:(07)00:41:08:000
00:48:06.000 : en:(08)00:48:06:000
00:55:43.000 : en:(09)00:55:43:000
01:01:49.000 : en:(10)01:01:49:000
01:06:51.000 : en:(11)01:06:51:000
01:11:22.000 : en:(12)01:11:22:000
01:16:47.000 : en:(13)01:16:47:000
01:22:42.000 : en:(14)01:22:42:000
01:32:06.000 : en:(15)01:32:06:000
01:43:40.000 : en:(16)01:43:40:000
01:47:13.000 : en:(17)01:47:13:000
Danneauxs
Format : Matroska
File size : 660 MiB
Duration : 1h 40mn
Video
Format : AVC
Duration : 1h 40mn
Bit rate : 775 Kbps
Width : 720 pixels
Height : 306 pixels
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1h 40mn
Bit rate : 128 Kbps
Bit depth : 16 bits
Language : English
Default : Yes
Forced : No
Text
Format : VobSub
Codec ID : S_VOBSUB
Language : English
Default : Yes
Forced : No
Menu
Format : Matroska
File size : 654 MiB
Duration : 1h 31mn
Video
Format : AVC
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 31mn
Default : Yes
Forced : No
Menu
Format : Matroska
File size : 708 MiB
Duration : 1h 47mn
Video
Format : AVC
Duration : 1h 47mn
Bit rate : 775 Kbps
Width : 720 pixels
Height : 304 pixels
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1h 47mn
Bit rate : 128 Kbps
Bit depth : 16 bits
Language : English
Default : Yes
Forced : No
Text
Format : VobSub
Codec ID : S_VOBSUB
Language : English
Default : Yes
Forced : No
Menu
