Subtitles and 1080p Movies
MarcSant
Post by MarcSant »
I'm encoding an 1080p movie, watching in VLC subs are showed perfectly, but, encoding in UMS don't. Encoding other resolution movies work as expected, with no change in configuration. I'm missing some config or this is a well know bug, or something else?
Re: Subtitles and 1080p Movies
Resolution shouldn't make a difference to subtitles. Try using the TRANSCODE folder to manually select subtitles
