XBox 360 minor issues
This is a great software. Nothing worked this well with my XBox before. However, I have some minor things that are not working.
1) The artwork for the movies is in the same folder. But XBox does not display the art. It shows the file but does not display the image. So e.g. if there is a file called movie.mkv and an image file called movie.jpg it shows both when I go into the videos (or folders). Ideally it should just show the movie and the image on the right side. Maybe it is a configuration issue that someone could help me with. In addition, I found two Thumbnail settings that I have added to the Xbox360.conf file.
ThumbnailAsResource=true
ForceJPGThumbnails=true
However, their addition had absolutely no effect on Thumbnails being shown. So I guess there is something else that I am missing here.
2) Subtitles, when present in the mkv file are loaded automatically. I don't know how to shut them off during playtime. Is there any way in XBox to disable them? Alternatively, is there any configuration setting to enable subtitles only when requested and *not* by default?
3) Any way to sort the movies by time, etc.? Currently it always shows them alphabetically and as I add more folders, it is slowly becoming unmanageable.
Thanks for a great software again. If someone could assist in answering my questions above, then that would be great.
