No renderers were found
Hi, the server wont work and i just dont know why ... I use it with my Ps3 since 1 year maybe more, my router just update few day aga but when i disable the firewall, ums dont work. I dont know what to do because the log of UMS say : The server is now available for renderers to find.
Help me plz.
Help me plz.
- Log
- (13.52 KiB) Downloaded 564 times
Re: No renderers were found
Hi I checked your log and I could not find any problem with UMS.
Since you only changed something on the router and you tested with firewall down, I suspect a setting in the router.
Can you logon to the router and check if UPNP is enabled in the router?
If it's not, enable it and test again.
