Version 4.0.1 is released
General:
This release adds options for greater control over subtitles, optimizes bandwidth use for better wireless performance, improves file compatibility and fixes several bugs!
Changes since 4.0.0:
  • General:
    • Added option InternalSubtitlesSupported to renderer configs for greater control over file compatibility
    • Added option "Force external subtitles"
    • Added the option "Use embedded style" to FFmpeg instead of just MEncoder
    • Fixed a bug with the adaptive bitrate setting GUI
    • Fixed bugs with subtitles not being loaded
    • Fixed displaying the Windows-specific "prevent operating system from sleeping" option on other operating systems
    • Fixed FFmpeg sometimes sending too many audio channels
    • Fixed FFmpeg using a bitrate too high for audio transcoding
  • Languages:
    • Updated Spanish translation (thanks, AlfredoRamos!)
  • External Components:
    • Updated FFmpeg to builds from 2014-07-16, which:
      • Improves support for many containers and codecs
      • Fixes bugs
Madoka
Re: Version 4.0.1 is released
Post by Madoka »
Thanks for the new release!! Gonna go test. :D
Gareee
Post by Gareee »
Looks like 4.01 cleared up the mp4 playback issue 4.00 had. ;)
SuperDre
Post by SuperDre »
Hmmm.. I saw with the latest version ffmpeg was set as default... And even though you said mencoder uses ffmpeg, whenever I have ffmpeg it stays black (for a long time) but when I start with mencoder it almost immediatly starts.. gonna set mencoder back to default in my setup..
snakebyte
Post by snakebyte »
@Subjunk,
I experience exactly the same with ffmpeg as SuperDre and choose for mencoder instead for the primary transcoder.
The issue however is not related to the latest UMS release , but is already there since I started using UMS about 1,5 years ago.
Everytime an update of the ffmpeg decoder arrives , I will try this immediately just to see the progress made.
The problem is almost never occuring with the first file that is decoded (this will start pretty fast) , but every file following will take more time to start with ultimately resulting in a server time out.
I already tried this with Mac OSX 10.8 as Mavericks and with the various Java versions being 6,7 and 8 and all on the latest build , but no changes yet.
It looks like ffmpeg creates some kind of cluther in the Java or UMS working methode.
Greetsssssssssss,
Snakebyte
SuperDre
Post by SuperDre »
ah, never used ffmpeg because mencoder just worked.. I'm still using the phat PS3 as renderer...
inuya5ha
Post by inuya5ha »
Downloading (manually) :geek:
The Auto Update dialog downloaded a huge file just to show the message "Error: Unable to run update. You may need to manually download it." :?
matush
Post by matush »
Subtitles stopped working after the update, can someone tell me what to do? I am streaming on my Samsung Smart TV (UE40F6400), everything worked without any problems on 3 and 4.0 version.
EDIT: I installed 4.0 version for now, until the bug is resolved. Subtitles on 4.0 are working without a hitch.
Bosck
Post by Bosck »
Live subtitles not working for me with MP4. I'm using 3.6.4 for now.
Sony Bravia W series and ubuntu 14.04.
Janz
Post by Janz »
matush wrote:Subtitles stopped working after the update, can someone tell me what to do? I am streaming on my Samsung Smart TV (UE40F6400), everything worked without any problems on 3 and 4.0 version.
Same problem here. External subtitles at least stopped working in 4.0.1, I also installed 4.0 and it's OK again. Also at least for me the external subtitles are not overriding internals in 4.0 either, worked fine though in beta version..
