Panasonic WTW60 & avi
Hi, i have a big problem with avis, they have always on the right side, no end
Anyone know some help?
- IMG_20140831_082849.jpg (2.5 MiB) Viewed 9702 times
Re: Panasonic WTW60 & avi
Rly, nobody knows help?
rly nobody know this problem?!
It only happen on my panasonic...
I have the same problem with some videos. You can set in the Panasonic.conf to avoid that problem. But it is CPU demanding. In that case you can also set to reduce the CPU workload.
RescaleByRenderer=false
MaxVideoWidth=1280
MaxVideoHeight=720
Hi crack00r, if it's still happening with the latest version can you please make logs by following the link in my signature?
I made some test and it seems to me that Panasonic TVs have a problem with the 4:3 aspect ratio padded to 16:9 for resolution 640x480. When the and resolution is 640x480 it shows the video like crack00r send. For lower resolution like 512x384 or 320x240 it works correctly. So the only fix for now is to set
KeepAspectRatio = true
KeepAspectRatio = false
Same here, maybe they fix it in next rls
This is fixed in 4.2.0 which will be released soon
