Where Do I Download The Beta Builds?
I browsed the forum and the website, but couldn't find any Beta builds.
Are they available to anyone? If so, where?
- SharkHunter
- Developer
Re: Where Do I Download The Beta Builds?
I think you do your own beta build via the UMSBuilder.
OK.SharkHunter wrote:I think you do your own beta build via the UMSBuilder.
I will have to look into that.
Can you please direct me where to start?
There's an specific forum for UMSbuilder at viewforum.php?f=25Dypsis wrote:OK.SharkHunter wrote:I think you do your own beta build via the UMSBuilder.
Also you can use forums' search functionality to capture other comments about UMSbuilder around.
Thanks Wolfgan.
