ALL Files Show As MPEG After Update to 4.1.2-Java7 [Solved]
lopanrs
Post by lopanrs »
Hello people, first post here.
I've using the great UMS for a while (since 3.4) and after spend some time configuring it. Finaly works with external subtitles and no transcoding in version 3.6.4.
Today, after upgrade with a clean install to 4.1.2 there's no way to load the .srt subtitles without transcoding and it uses a lot of CPU and bandwidth and the main problem is that i`m not able to seek the movie, it restarts from the beginning.
My renderer is a LG-42LA6200, to load the external .srt file i've put the line:
SupportedSubtitlesType = SUBRIP
into LG-LA6200.conf file
and set up the subtitles definition with:
The same configs in 4.1.2 render the movie with MPEG2 transcoding, render the subtitles via UMS and no seek, always returns to the beginning of the movie.
Thank you for the UMS project and sorry my poor english. ;)
Re: ALL Files Show As MPEG After Update to 4.1.2-Java7
lopanrs wrote:Hello people, first post here.
Hi lopanrs, welcome to the forum :) In 4.1.2 we split the renderer option SupportedSubtitlesFormats into SupportedExternalSubtitlesFormats and SupportedInternalSubtitlesFormats
lopanrs
Post by lopanrs »
Thank You for quick reply, it works now. It's in the changelog of 4.1.1. i did not realize. :)
Re: ALL Files Show As MPEG After Update to 4.1.2-Java7 [Solv
No problem, glad to help :)
