[Solved] Audio file not recognized
jps92
Post by jps92 »
With the latest version 5.0.0 -a1 i can not read files (PCM) .WAV on my yamaha R- N500 from which I created a file.conf (based on the streamium.conf file). It says "file not recognized". It worked before on 4.2.0. I think my renderer is no more well knowed (that the same under windows).
Thank you for your work.
Re: Audio file not recognized
Hi, please make logs for it :)
jps92
Post by jps92 »
I arranged it by adding "transcodeaudio=wav"
Re: [Solved] Audio file not recognized
Thanks, this will be added in the next version
