Xbox One does not see UMS
My Xbox One stopped seeing UMS recently, it was working for a few weeks then stopped last week. When you open up Media Player on the Xbox it states that no devices were detected.
My 360 is able to connect and play content without issue. The computer, Xbox, switch, and router have all been rebooted. I reset al settings in UMS, set it back up and reinstalled Media Player on the Xbox.
I have attached the logs, for simplicity the 360 was not on when I recreated the issue, however, it appears that UMS thinks the 360 tried to connect.
- (16.81 KiB) Downloaded 532 times
Re: Xbox One does not see UMS
Anyone here had success using UMS 4.2.0 with the Xbox One?
I installed 4.2.1 and the same issue happens. I noticed that UMS sees my Xbox as a 360, when I force Xbox One as the renender the Xbox One works and the 360 does not. When I force Unknown Renender as the renender both work, any idea why UMS is unable to detect the Xbox One properly?
Did you fix your issue? My XB1 was working fine then recently it stopped seeing UMS. I ended up downloading version 5.00-a1 and it now see UMS again.
Hey guys, we have fixed this issue and will release it soon, in the meantime you can use this version which should work: http://www.spirton.com/uploads/UMS/UMS-3ce8fdb.exe
Yes, had exact same issue, was working OK but then since the Xbox Nov update it appears not to.
Sorry for the delayed response, these emails went to my junk folder.
The most recent update fixed my issue, all good now.
Re: [Solved] Xbox One does not see UMS
I am having the same issue and tried the fix you posted above and still no luck. I attached my logs
- (15.39 KiB) Downloaded 509 times
Please make logs using this version of UMS, it is a build made specifically for debugging this issue: http://www.spirton.com/uploads/UMS/UMS-764ce59.exe
Updated special build for debugging this issue (try also the one above): UMS-1bbfc78.exe.
