Unshared maps in UMS on my tv
Hey
Got a problem. UMS shows a folder called WEB on my tv that isnt mine. Its located in the temp directory for UMS and contains pictures of asians and TED talks videos. I havent shared this and its not mine. If i delete it it reappears and shows up on my tv in the folder WEB. If I delete the pics and movies from the tempfolder the regenerate???
Help anyone!!
Help anyone!!
- SharkHunter
- Developer
Re: Unshared maps in UMS on my tv
The WEB folder is part of the UMS delivery (and has been so since the dawn of time). It contains sample WEB URLs that you can stream via UMS. If you don't want it you can either remove the WEB.conf file (found at the same place as your UMS.conf).
Thank u so much!
Had UMS for a year and never seen the folder before last night.
