for SubJunk UMS-5.0.0-b1-Java7+
shaina
Post by shaina »
Hi SubJunk
here is the log file you requested to try to fix xbox360 .conf
also something weird is happening ??
all of my hard drives and files are showing up in All Photos folder and they will play but no other functions like fast forward of rewind are working
thanks in advance for trying to fix this problem
shaina
xbox360 .conf
(34.11 KiB) Downloaded 481 times
Re: for SubJunk UMS-5.0.0-b1-Java7+
Hi shaina, thanks for the logs! Is the problem that you can't browse the videos, or what exactly is the problem?
shaina
ignor this post
Post by shaina »
ignor this post
shaina
Post by shaina »
SubJunk wrote:Hi shaina, thanks for the logs! Is the problem that you can't browse the videos, or what exactly is the problem?
Hi SubJunk
on the playback I noticed a studder in the playback plus the actual disk drive folders don't show up
I got lucky I clicked on All Photos folder and the drives and all the files were in there but normally just the drives where the movies and tv shows show up it is like photo folders and a iso folders on startup
and you get no fast forward or reverse functions if you try to it starts from the beginning again
thanks
shaina
