UMS Start when Windows Start
stuart_waring
Post by stuart_waring »
This may be because of something i have done that is ridiculously dumb, but I recently installed UMS in place of PMS, but the program will not automatically load when windows start (the box is checked under General Configuration). It may be to do with the fact that whenever i try to load UMS it brings up the User Account Control dialog box as it says the publisher is unknown.
I am loathe to reduce the security settings as they would have to be turned off completely. Any ideas?
Many thanks
Stuart
(14.24 KiB) Downloaded 210 times
stuart_waring
Re: UMS Start when Windows Start
I have found a solution - I have scheduled it to start using the Task Scheduler under computer management .
Ticking "Run with highest priveledges" bypasses the UAC pop up
