Denon 2112CI
Shade
Denon 2112CI
Post by Shade »
I have an issue with my Denon 2112CI. I am able to use UMS to stream mp3s directly to the receiver however when I try to stream FLAC files which the receiver supports I receive a File Format Error. Is it possible to get a plugin or fix so this will stream correctly? I'm not sure if this applicable to other Denon receiver's in this line or just the 2112. Thanks!
Re: Denon 2112CI
Hi Shade, welcome to the forum!
We don't support that device yet, so maybe you can help us add support for it :)
First, what is it detected as in the program? Which name shows up in the "Detected media renderers" section of the Status tab?
Shade
Re: Denon 2112CI
Post by Shade »
I have several listed, but I believe it is showing up as either Streamium or Unknown renderer. I don't have a Streamium. I thought it used to show the IP address of each renderer, then I could tell you specifically which one it is.
Re: Denon 2112CI
The IP address is still listed in the Traces tab, can you check to make sure?
Shade
Re: Denon 2112CI
Post by Shade »
Confirmed, it is showing up as a Streamium. Do you need any additional info?
Re: Denon 2112CI
OK great. Now we need to find out how to make the program differentiate between the Denon and Streamium.
To do this, please go into your program installation directory and delete Streamium.conf from the renderers folder, then start the program with your Denon renderer turned on.
In the Traces tab you should see one or more lines of "Media renderer was not recognized. Possible identifying HTTP headers: ". If you copy those line/s here that will let me make the renderer file :)
Shade
Re: Denon 2112CI
Post by Shade »
Is this what you needed?
INFO 2012-06-06 20:50:41.815 [New I/O server worker #2-12] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0
Re: Denon 2112CI
Can you please do it again and attach or paste the whole debug.log file?
Shade
Re: Denon 2112CI
Post by Shade »
Won't let me attach text files... so here it is pasted.
DEBUG 2012-06-06 20:48:24.215 [main] Java version: 1.7.0_04
DEBUG 2012-06-06 20:48:24.216 [main] Java vendor: Oracle Corporation
DEBUG 2012-06-06 20:48:24.216 [main] Java class path: update.jar;ums.jar
DEBUG 2012-06-06 20:48:24.216 [main] Operating system name: Windows 7
DEBUG 2012-06-06 20:48:24.216 [main] Operating system architecture: x86
DEBUG 2012-06-06 20:48:24.216 [main] Operating system version: 6.1
DEBUG 2012-06-06 20:48:24.265 [main] SUN 1.7: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
DEBUG 2012-06-06 20:48:24.265 [main] SunRsaSign 1.7: Sun RSA signature provider
DEBUG 2012-06-06 20:48:24.265 [main] SunEC 1.7: Sun Elliptic Curve provider (EC, ECDSA, ECDH)
DEBUG 2012-06-06 20:48:24.265 [main] SunJSSE 1.7: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
DEBUG 2012-06-06 20:48:24.265 [main] SunJCE 1.7: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
DEBUG 2012-06-06 20:48:24.265 [main] SunJGSS 1.7: Sun (Kerberos v5, SPNEGO)
DEBUG 2012-06-06 20:48:24.265 [main] SunSASL 1.7: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5, NTLM; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5, NTLM)
DEBUG 2012-06-06 20:48:24.265 [main] XMLDSig 1.0: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
DEBUG 2012-06-06 20:48:24.265 [main] SunPCSC 1.7: Sun PC/SC provider
DEBUG 2012-06-06 20:48:24.265 [main] SunMSCAPI 1.7: Sun's Microsoft Crypto API provider
DEBUG 2012-06-06 20:48:24.267 [main] Set parameter http.useragent = Jakarta Commons-HttpClient/3.1
DEBUG 2012-06-06 20:48:24.268 [main] Set parameter http.protocol.version = HTTP/1.1
DEBUG 2012-06-06 20:48:24.269 [main] Set parameter http.connection-manager.class = class org.apache.commons.httpclient.SimpleHttpConnectionManager
DEBUG 2012-06-06 20:48:24.269 [main] Set parameter http.protocol.cookie-policy = default
DEBUG 2012-06-06 20:48:24.269 [main] Set parameter http.protocol.element-charset = US-ASCII
DEBUG 2012-06-06 20:48:24.269 [main] Set parameter http.protocol.content-charset = ISO-8859-1
DEBUG 2012-06-06 20:48:24.270 [main] Set parameter http.method.retry-handler = org.apache.commons.httpclient.DefaultHttpMethodRetryHandler@56cd93
DEBUG 2012-06-06 20:48:24.270 [main] Set parameter http.dateparser.patterns = [EEE, dd MMM yyyy HH:mm:ss zzz, EEEE, dd-MMM-yy HH:mm:ss zzz, EEE MMM d HH:mm:ss yyyy, EEE, dd-MMM-yyyy HH:mm:ss z, EEE, dd-MMM-yyyy HH-mm-ss z, EEE, dd MMM yy HH:mm:ss z, EEE dd-MMM-yyyy HH:mm:ss z, EEE dd MMM yyyy HH:mm:ss z, EEE dd-MMM-yyyy HH-mm-ss z, EEE dd-MMM-yy HH:mm:ss z, EEE dd MMM yy HH:mm:ss z, EEE,dd-MMM-yy HH:mm:ss z, EEE,dd-MMM-yyyy HH:mm:ss z, EEE, dd-MM-yyyy HH:mm:ss z]
DEBUG 2012-06-06 20:48:24.409 [pool-2-thread-1] Open connection to universal-media-server.googlecode.com:80
DEBUG 2012-06-06 20:48:24.565 [pool-2-thread-1] >> "GET /git/src/main/external-resources/update/update_3.properties?currentVersion=1.0.1&operatingSystem=windows&cacheBuster=0.9185958247814948 HTTP/1.1[\r][\n]"
DEBUG 2012-06-06 20:48:24.565 [pool-2-thread-1] Adding Host request header
DEBUG 2012-06-06 20:48:24.573 [pool-2-thread-1] >> "User-Agent: Jakarta Commons-HttpClient/3.1[\r][\n]"
DEBUG 2012-06-06 20:48:24.573 [pool-2-thread-1] >> "Host: universal-media-server.googlecode.com[\r][\n]"
DEBUG 2012-06-06 20:48:24.573 [pool-2-thread-1] >> "[\r][\n]"
DEBUG 2012-06-06 20:48:24.674 [pool-2-thread-1] << "HTTP/1.1 200 OK[\r][\n]"
DEBUG 2012-06-06 20:48:24.674 [pool-2-thread-1] << "ETag: "36393333343738666262383332316438383030356437306666336663306531343363646631626161/src/main/external-resources/update/update_3.properties"[\r][\n]"
DEBUG 2012-06-06 20:48:24.674 [pool-2-thread-1] << "Date: Thu, 07 Jun 2012 00:48:24 GMT[\r][\n]"
DEBUG 2012-06-06 20:48:24.675 [pool-2-thread-1] << "Cache-Control: public,max-age=60[\r][\n]"
DEBUG 2012-06-06 20:48:24.675 [pool-2-thread-1] << "Accept-Ranges: none[\r][\n]"
DEBUG 2012-06-06 20:48:24.675 [pool-2-thread-1] << "Content-Type: text/plain; charset=ISO-8859-1[\r][\n]"
DEBUG 2012-06-06 20:48:24.675 [pool-2-thread-1] << "X-Content-Type-Options: nosniff[\r][\n]"
DEBUG 2012-06-06 20:48:24.675 [pool-2-thread-1] << "Server: git_frontend[\r][\n]"
DEBUG 2012-06-06 20:48:24.675 [pool-2-thread-1] << "X-XSS-Protection: 1; mode=block[\r][\n]"
DEBUG 2012-06-06 20:48:24.675 [pool-2-thread-1] << "Transfer-Encoding: chunked[\r][\n]"
DEBUG 2012-06-06 20:48:24.675 [pool-2-thread-1] << "[\r][\n]"
WARN  2012-06-06 20:48:24.677 [pool-2-thread-1] Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] Buffering response body
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] << "6"
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] << "f"
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] << "[\r]"
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] << "[\n]"
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] << "LatestVersion="1.0.1"[\r][\n]"
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] << "DownloadUrl.windows="http://universal-media-server.googlecode.com/files/UMS-1.0.1.exe"[\r][\n]"
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] << "0"
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] << "[\r][\n]"
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] Resorting to protocol version default close connection policy
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] Should NOT close connection, using HTTP/1.1
DEBUG 2012-06-06 20:48:24.678 [pool-2-thread-1] Releasing connection back to connection manager.
INFO  2012-06-06 20:48:24.962 [main] Starting Universal Media Server 1.0.1
INFO  2012-06-06 20:48:24.975 [main] Based on PS3 Media Server (ps3mediaserver.org) by shagrath, copyright 2008-2012
INFO  2012-06-06 20:48:24.980 [main] http://www.universalmediaserver.com
INFO  2012-06-06 20:48:24.982 [main]
INFO  2012-06-06 20:48:24.983 [main] Build: 4834eed2c (2012-06-03)
INFO  2012-06-06 20:48:24.983 [main] Java: 1.7.0_04-Oracle Corporation
INFO  2012-06-06 20:48:24.984 [main] OS: Windows 7 x86 6.1
INFO  2012-06-06 20:48:24.985 [main] Encoding: UTF-8
INFO  2012-06-06 20:48:24.986 [main]
INFO  2012-06-06 20:48:24.986 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-06-06 20:48:24.991 [main] Temp folder: C:\Users\Shade\AppData\Local\Temp\ps3mediaserver
INFO  2012-06-06 20:48:24.993 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2012-06-06 20:48:24.993 [main] debug.log: C:\Users\Shade\AppData\Local\Temp\\debug.log
INFO  2012-06-06 20:48:24.994 [main] Profile directory: C:\ProgramData\UMS
INFO  2012-06-06 20:48:24.994 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2012-06-06 20:48:24.994 [main] Profile status: rw
INFO  2012-06-06 20:48:24.994 [main] Profile name: Shade-PC
INFO  2012-06-06 20:48:24.995 [main]
INFO  2012-06-06 20:48:24.997 [main] Loading MediaInfo library
INFO  2012-06-06 20:48:25.062 [main] Loaded MediaInfoLib - v0.7.57
INFO  2012-06-06 20:48:25.066 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2012-06-06 20:48:25.066 [main] Loading configuration file: AirPlayer.conf
DEBUG 2012-06-06 20:48:25.067 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/AirPlayer.conf
INFO  2012-06-06 20:48:25.069 [main] Loading configuration file: Android.conf
DEBUG 2012-06-06 20:48:25.069 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Android.conf
INFO  2012-06-06 20:48:25.070 [main] Loading configuration file: Bravia4500.conf
DEBUG 2012-06-06 20:48:25.071 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Bravia4500.conf
INFO  2012-06-06 20:48:25.072 [main] Loading configuration file: Bravia5500.conf
DEBUG 2012-06-06 20:48:25.072 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Bravia5500.conf
INFO  2012-06-06 20:48:25.073 [main] Loading configuration file: BraviaEX.conf
DEBUG 2012-06-06 20:48:25.074 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/BraviaEX.conf
INFO  2012-06-06 20:48:25.076 [main] Loading configuration file: Dlink510.conf
DEBUG 2012-06-06 20:48:25.076 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Dlink510.conf
INFO  2012-06-06 20:48:25.077 [main] Loading configuration file: FreeboxHD.conf
DEBUG 2012-06-06 20:48:25.078 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/FreeboxHD.conf
INFO  2012-06-06 20:48:25.079 [main] Loading configuration file: FreecomMusicPal.conf
DEBUG 2012-06-06 20:48:25.079 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/FreecomMusicPal.conf
INFO  2012-06-06 20:48:25.080 [main] Loading configuration file: iPad-iPhone.conf
DEBUG 2012-06-06 20:48:25.080 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/iPad-iPhone.conf
INFO  2012-06-06 20:48:25.081 [main] Loading configuration file: Kuro.conf
DEBUG 2012-06-06 20:48:25.082 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Kuro.conf
INFO  2012-06-06 20:48:25.082 [main] Loading configuration file: N900.conf
DEBUG 2012-06-06 20:48:25.083 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/N900.conf
INFO  2012-06-06 20:48:25.083 [main] Loading configuration file: Panasonic.conf
DEBUG 2012-06-06 20:48:25.084 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Panasonic.conf
INFO  2012-06-06 20:48:25.085 [main] Loading configuration file: Philips.conf
DEBUG 2012-06-06 20:48:25.086 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Philips.conf
INFO  2012-06-06 20:48:25.086 [main] Loading configuration file: PhilipsPFL.conf
DEBUG 2012-06-06 20:48:25.087 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PhilipsPFL.conf
INFO  2012-06-06 20:48:25.089 [main] Loading configuration file: PopcornHour.conf
DEBUG 2012-06-06 20:48:25.089 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PopcornHour.conf
INFO  2012-06-06 20:48:25.090 [main] Loading configuration file: PS3.conf
DEBUG 2012-06-06 20:48:25.090 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/PS3.conf
INFO  2012-06-06 20:48:25.092 [main] Loading configuration file: Realtek.conf
DEBUG 2012-06-06 20:48:25.093 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Realtek.conf
INFO  2012-06-06 20:48:25.094 [main] Loading configuration file: SamsungAllShare.conf
DEBUG 2012-06-06 20:48:25.094 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SamsungAllShare.conf
INFO  2012-06-06 20:48:25.095 [main] Loading configuration file: SamsungWiseLink.conf
DEBUG 2012-06-06 20:48:25.098 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SamsungWiseLink.conf
INFO  2012-06-06 20:48:25.099 [main] Loading configuration file: Showtime3.conf
DEBUG 2012-06-06 20:48:25.099 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/Showtime3.conf
INFO  2012-06-06 20:48:25.100 [main] Loading configuration file: SonyBluray.conf
DEBUG 2012-06-06 20:48:25.101 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/SonyBluray.conf
INFO  2012-06-06 20:48:25.102 [main] Loading configuration file: WDTVLive.conf
DEBUG 2012-06-06 20:48:25.102 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/WDTVLive.conf
INFO  2012-06-06 20:48:25.103 [main] Loading configuration file: WMP.conf
DEBUG 2012-06-06 20:48:25.103 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/WMP.conf
INFO  2012-06-06 20:48:25.104 [main] Loading configuration file: XBMC.conf
DEBUG 2012-06-06 20:48:25.104 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/XBMC.conf
INFO  2012-06-06 20:48:25.105 [main] Loading configuration file: XBOX360.conf
DEBUG 2012-06-06 20:48:25.105 [main] Base path set to file:///C:/Program%20Files%20(x86)/Universal%20Media%20Server/renderers/XBOX360.conf
INFO  2012-06-06 20:48:25.106 [main] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-06-06 20:48:25.106 [main] launching: win32/mplayer.exe
DEBUG 2012-06-06 20:48:25.178 [main] launching: win32/mplayer.exe
INFO  2012-06-06 20:48:25.249 [main] Done!
INFO  2012-06-06 20:48:25.252 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2012-06-06 20:48:25.253 [main] No plugins found
INFO  2012-06-06 20:48:25.260 [main] Transcoder profile AviSynth/FFmpeg will not be used because AviSynth was not found
INFO  2012-06-06 20:48:25.261 [main] Registering transcoding engine: FFmpeg Audio
INFO  2012-06-06 20:48:25.264 [main] Registering transcoding engine: MEncoder
INFO  2012-06-06 20:48:25.264 [main] Transcoder profile AviSynth/MEncoder will not be used because AviSynth was not found
INFO  2012-06-06 20:48:25.265 [main] Registering transcoding engine: MPlayer Audio
INFO  2012-06-06 20:48:25.265 [main] Registering transcoding engine: MEncoder Web
INFO  2012-06-06 20:48:25.265 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2012-06-06 20:48:25.266 [main] Registering transcoding engine: MPlayer Web
INFO  2012-06-06 20:48:25.267 [main] Registering transcoding engine: tsMuxeR
INFO  2012-06-06 20:48:25.267 [main] Registering transcoding engine: Audio High Fidelity
INFO  2012-06-06 20:48:25.267 [main] Executable of transcoder profile VLC Audio Streaming not found
INFO  2012-06-06 20:48:25.267 [main] Executable of transcoder profile VLC Video Streaming not found
INFO  2012-06-06 20:48:25.268 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-06-06 20:48:25.268 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-06-06 20:48:25.268 [main] AviSynth is not installed. You cannot use avsmencoder as a transcoding engine.
INFO  2012-06-06 20:48:25.386 [main] Using address /192.168.1.64 found on network interface: name:eth3 (Realtek PCIe GBE Family Controller)
INFO  2012-06-06 20:48:25.387 [main] Created socket: /192.168.1.64:5001
DEBUG 2012-06-06 20:48:25.476 [main] Sending ALIVE...
INFO  2012-06-06 20:48:25.497 [main] Using the following UUID configured in UMS.conf: 25a45f75-640e-4ebc-83d9-ac18a822720d
INFO  2012-06-06 20:48:25.553 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.1.68
INFO  2012-06-06 20:48:25.557 [New I/O server worker #1-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0
INFO  2012-06-06 20:48:25.557 [New I/O server worker #1-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:48:25.574 [New I/O server worker #1-3] No IP filter specified, access granted to /192.168.1.70
INFO  2012-06-06 20:48:25.575 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-7.2, UPnP/1.0 DIRECTV JHUPnP/1.0
INFO  2012-06-06 20:48:25.575 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-7.2, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:48:25.578 [New I/O server worker #1-5] No IP filter specified, access granted to /192.168.1.69
INFO  2012-06-06 20:48:25.579 [New I/O server worker #1-5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0
INFO  2012-06-06 20:48:25.603 [New I/O server worker #1-6] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:48:26.115 [New I/O server worker #1-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-7.2, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:48:26.115 [New I/O server worker #1-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-7.2, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:48:26.166 [New I/O server worker #1-6] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:48:26.172 [New I/O server worker #1-5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:48:26.461 [New I/O server worker #1-7] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:48:26.462 [New I/O server worker #1-8] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:48:27.733 [New I/O server worker #1-9] No IP filter specified, access granted to /192.168.1.76
INFO  2012-06-06 20:48:27.735 [pool-7-thread-1] Checking IP: 192.168.1.76 for Samsung AllShare
INFO  2012-06-06 20:48:27.746 [pool-7-thread-1] Renderer Samsung AllShare found on this address: unknownD0667BE5BB76 (192.168.1.76)
DEBUG 2012-06-06 20:48:27.750 [pool-7-thread-1] Starting ping -n 3 -l 64000 192.168.1.76
INFO  2012-06-06 20:48:28.183 [New I/O server worker #1-10] No IP filter specified, access granted to /192.168.1.65
INFO  2012-06-06 20:48:28.184 [pool-7-thread-2] Checking IP: 192.168.1.65 for WMP
INFO  2012-06-06 20:48:28.194 [pool-7-thread-2] Renderer WMP found on this address: Ligeia-PC (192.168.1.65)
DEBUG 2012-06-06 20:48:28.195 [pool-7-thread-2] Starting ping -n 3 -l 64000 192.168.1.65
DEBUG 2012-06-06 20:48:29.750 [SpeedStats Failsafe] Stopping process: ping-0
INFO  2012-06-06 20:48:29.751 [pool-7-thread-1] Address /192.168.1.76 has an estimated network speed of: 24 Mb/s
DEBUG 2012-06-06 20:48:30.195 [SpeedStats Failsafe] Stopping process: ping-1
INFO  2012-06-06 20:48:30.196 [pool-7-thread-2] Address /192.168.1.65 has an estimated network speed of: 85 Mb/s
INFO  2012-06-06 20:48:30.643 [main] The server should now appear on your renderer
DEBUG 2012-06-06 20:48:40.644 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 20:49:05.468 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 20:49:19.943 [background-task-0] singleton task restart started
DEBUG 2012-06-06 20:49:19.943 [background-task-0-restart(0)] task started
INFO  2012-06-06 20:49:19.943 [background-task-0-restart(0)] Sending BYEBYE...
INFO  2012-06-06 20:49:24.564 [background-task-0-restart(0)] Stopping server on host 192.168.1.64 and port 5001...
INFO  2012-06-06 20:49:25.608 [background-task-0-restart(0)] Using address /192.168.1.64 found on network interface: name:eth3 (Realtek PCIe GBE Family Controller)
INFO  2012-06-06 20:49:25.608 [background-task-0-restart(0)] Created socket: /192.168.1.64:5001
DEBUG 2012-06-06 20:49:25.609 [background-task-0-restart(0)] Sending ALIVE...
INFO  2012-06-06 20:49:25.649 [New I/O server worker #2-1] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-7.2, UPnP/1.0 DIRECTV JHUPnP/1.0
INFO  2012-06-06 20:49:25.651 [New I/O server worker #2-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-7.2, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:49:25.673 [New I/O server worker #2-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:49:25.687 [New I/O server worker #2-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0
INFO  2012-06-06 20:49:25.703 [New I/O server worker #2-5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0
INFO  2012-06-06 20:49:25.713 [New I/O server worker #2-6] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:49:26.200 [New I/O server worker #2-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-7.2, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:49:26.201 [New I/O server worker #2-4] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-7.2, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:49:26.361 [New I/O server worker #2-5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:49:26.362 [New I/O server worker #2-6] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:49:26.505 [New I/O server worker #2-7] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
INFO  2012-06-06 20:49:26.532 [New I/O server worker #2-8] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/2.6.18-lttng-0.6.41, UPnP/1.0 DIRECTV JHUPnP/1.0 DLNADOC/1.00 DIRECTV VIIV devices INTEL_NMPR/2.1
DEBUG 2012-06-06 20:49:30.280 [background-task-0-restart(0)] task ended
INFO  2012-06-06 20:50:41.814 [New I/O server worker #2-12] No IP filter specified, access granted to /192.168.1.73
DEBUG 2012-06-06 20:52:09.522 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 20:55:13.972 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 20:58:19.690 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:01:24.295 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:04:30.143 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:07:35.322 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-06 21:07:50.824 [New I/O server worker #2-15] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0
INFO  2012-06-06 21:08:08.065 [UPNPHelper] No IP filter specified, access granted to /192.168.1.64
INFO  2012-06-06 21:08:10.137 [New I/O server worker #2-16] Another renderer like WMP was found!
INFO  2012-06-06 21:08:10.138 [pool-7-thread-3] Checking IP: 192.168.1.64 for WMP
INFO  2012-06-06 21:08:10.144 [pool-7-thread-3] Renderer WMP found on this address: Shade-PC.gateway.2wire.net (192.168.1.64)
DEBUG 2012-06-06 21:08:10.144 [pool-7-thread-3] Starting ping -n 3 -l 64000 192.168.1.64
DEBUG 2012-06-06 21:08:12.144 [SpeedStats Failsafe] Stopping process: ping-2
DEBUG 2012-06-06 21:08:12.145 [pool-7-thread-3] Could not parse time from "64000 time<1"
DEBUG 2012-06-06 21:10:38.884 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:13:44.566 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:16:48.805 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:19:53.882 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:22:58.721 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:26:03.616 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-06 21:26:09.986 [New I/O server worker #2-5] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0
DEBUG 2012-06-06 21:29:07.498 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:32:12.821 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:35:17.448 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:38:23.016 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:41:27.323 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:44:32.942 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:47:38.889 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:50:43.582 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:53:47.962 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:56:53.356 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 21:59:57.697 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-06 22:00:08.122 [New I/O server worker #2-12] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0
DEBUG 2012-06-06 22:03:01.079 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 22:06:05.849 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 22:09:09.813 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 22:12:14.693 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 22:15:18.356 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 22:18:23.131 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 22:21:27.756 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 22:24:32.520 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 22:27:36.434 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-06 22:30:10.277 [New I/O server worker #2-2] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0
DEBUG 2012-06-06 22:30:40.869 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-06-06 22:31:38.287 [New I/O server worker #2-3] Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: KnOS/3.2 bridgeCo-DMP/3.0 DLNADOC/1.50 INTEL_NMPR/2.0
DEBUG 2012-06-06 22:33:45.084 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-06-06 22:36:48.848 [UPNP-AliveMessageSender] Sending ALIVE...
Re: Denon 2112CI
Darn. It has exactly the same user-agent value as Streamium, so it's impossible to tell which one it is.
This has nothing to do with UMS, it just isn't giving any unique info that any program could use.
So what we'll do instead is try to add flac to the Streamium conf, since it looks like most Streamium devices support flac anyway.
Please replace Streamium.conf with this one and let me know if it works :)
Streamium.zip
(1.06 KiB) Downloaded 1475 times
