Panasonic Viera TX-32AS600E renderer
Etmoc
Post by Etmoc »
I use at home a Panasonic TX-32AS600E.
I've modifed the Panasonic Viera configuration file to display video without transcoding.
So you will find the trace of the discovery for this device and the modified configuration.
Thank you.
Etmoc
Panasonic_Viera_TX-32AS600E.zip
(23.85 KiB) Downloaded 483 times
Re: Panasonic Viera TX-32AS600E renderer
Thanks a lot, Etmoc! It will be in the next version :)
twistedLucidity
Post by twistedLucidity »
Should this work for a Panasonic Viera TX-42AS650B?
edit: Seems it does, I'll have to re-test with the default.
Happy to provide a proper trace log is anyone can tell me how to get to the web interface to enable logging (running UMS headless).
My previous problems appear to be caused by the TV being on the untrusted network. Once I put the server on to the untrusted network, it works.
