Telefunken TFL325070B
I used UMS for 2 days, and my Telefunken TV was not recognised, but music was played OK, except when needing transcoding.
I just tried the 5.0.0b1 version, and now it is. Capture.jpg is the picture of "Statut" page. The .flac files are no more played.
Please find attached capture.jpg and ums_dbg.zip files.
Thanks for this nice software, I used Plex before, which is slow and enormous compare to UMS.
Malo56.
Malo56.
- Capture.JPG (22.02 KiB) Viewed 15450 times
- (18.9 KiB) Downloaded 1048 times
Re: Telefunken TFL325070B
Hi Malo56, thanks for choosing UMS! I can't find the manual for that TV anywhere online, if you have it can you look through it and take a photo of a page that mentions file formats? If you post that here I can make the renderer config better.
Attached is a renderer config that tells UMS "serve flac, jpg and mpeg, and transcode everything else", you can use it by putting it into "C:\Program Files (x86)\Universal Media Server\renderers\"
Telefunken-TV.conf
- (794 Bytes) Downloaded 1142 times
Thanks for your answer. With your file .conf, my Telefunken TV is no more detected...
Here is a copy of the Telefunken audio-video specs.
Regards,
Malo.
Regards,
Malo.
- Specs audio-Video.jpg (267.03 KiB) Viewed 15434 times
