[Solved] Transcoding Settings panel is empty
pedropsousa
Post by pedropsousa »
First of all, thank you for this nice piece of software, and for making it freely available. :)
I've just installed UMS 4.4.0 for testing, and so far i'm really enjoying the software. This is my first time with this software so I never had any previous versions installed.
Anyways, I've found that my Transcoding Settings pane only has one option, which is the "Disable subtitles" one. No Audio / Video options appear whatsoever, although I'm not really sure if there are supposed to be any options there :lol: as I never played with this software before, but from what I've read, I guess that there should be something else more in there :?:
I've followed your instructions on new Topics, enabled the "Trace" options in log level :geek:, and went to the Transcoding settings to see if something came out from the logs, but I don't think so.
I've packed the log files through the UMS interface and included a screenshot of the Transcoding Settings panel itself. Hope you guys could help me to bring back those options to the panel.
Thanks in advance
Pedro Sousa
Logs packed along with a screenshot of the Transcoding Settings pane
(45.31 KiB) Downloaded 242 times
pedropsousa
Re: Transcoding Settings panel is empty
Guys, nevermind.
I've found the solution. I had to go to "General Configuration" panel, and untick "Hide advanced options (needs application restart).
Problem is solved.
Kind regards,
Pedro Sousa
