Stuttering
kwn2k
Stuttering
Post by kwn2k »
Im having problems with keeping the stream stutter free.
when i start streaming there goes a random amount of time and the device is looking for the stream again as if its closed down and then starts from the point is started to stutter.
i've included the debug from my last "stutter" and im using it wired..
(154.58 KiB) Downloaded 253 times
Re: Stuttering
Hi kwn2k :) It's transcoding subtitles onto a 1080p file so it's possible the CPU isn't fast enough to do that. You can see if that's the case by getting a 720p version of that file.
kwn2k
Re: Stuttering
Post by kwn2k »
sorry to bring this up again, but didnt notice the reply, and since then i have a new system where it does exactly the same thing, 720p and 1080p even on lower quality movies, but i've noticed that there the stutter / freeze im getting is when the server is sending [UPNP-AliveMessageSender] where it freezes for 1-3 sek and then continues, thats even with no subtitles on, since i cant use forced subtitles for some reason on either 5.01 and higher it just says file not supported, so all my srt files are not used in the stream.
if it helps im streaming to a Panasonic Viera E5 Series
i will upload a new debug if needed.
Re: Stuttering
new logs would be useful :)
kwn2k
Re: Stuttering
Post by kwn2k »
here you go the new debug logs fom a totally fresh install of windows 8.1 and UMS.
The TV im streaming to is Panasonic TX-L37E5Y SmartTV just to be more specific :)
(24.93 KiB) Downloaded 246 times
kwn2k
Re: Stuttering
Post by kwn2k »
just a little update.
just did a streaming test on both my xbox 360 and my PS3 with no problems at all no stuttering or sudden freezes and that was even over wifi and 1080p files, so i think its something with the way it streams to my TV..
but still havent gotten the srt subtitles to show up
