Not compatible file
patomas
Not compatible file
Post by patomas »
I try to watch an avi file and seems to be incompatible. The funny thing is that i can watch that file through the ps3 (using also usm). I am using pclinuxos and a Samsung Smart TV. Any help?
(13.37 KiB) Downloaded 273 times
Re: Not compatible file
Hi patomas, please go to the Transcoding Settings tab and enter "avi" into the "Force transcoding for..." setting at the bottom, and let me know if that works. If it does then I can include that fix in the next UMS version.
