[Solved] 2 UMS on the same network?
I have installed universal media server on 2 PCs in my network and on my tv i can se only one of them.
Can i run 2 universal media servers on my network?
Re: 2 UMS on the same network?
Hi bcip, yeah it should work, check your network settings
Re: 2 UMS on the same network? [SOLVED]
yeah...it was from my firewall. it was on automatic filtering, i switched to manual filtering and now works like a charm.
we can close this topic.
Thanks for confirming
