[SOLVED] Subtitles cropped with overscan compensation
glo5
Post by glo5 »
I am having a problem with subtitles betting cropped when using overscan compensation. They are ssa subtitles in the file.
I tried adjusting the values under the subtitle setting but it doesn't seem to do anything. I am using UMS 1.6.0.
When I play another file with .srt subtitles then I don't have problems with subtitles getting cropped.
Re: Subtitles getting cropped with overscan compensation
Thanks for reporting this. It is fixed now. If you tell me your operating system I can build you the latest code so you don't have to wait for the next release for your fix :)
glo5
Post by glo5 »
I am using windows 7.
Thanks.
glo5
Post by glo5 »
Thanks! This fixed the problem. :D
Great! Thanks for confirming
