Subtitles problem
Subtitles problem
Hi
I`ve got some problem with subtitles with my Samsung HU7200 TV. All works well but subtitles are somehow mixed.
It loads proper subtitle file but also the previous one used and mix it somehow.
Do You maybe know how to solve it ?
Please advise.
Please advise.
Re: Subtitles problem
Ive got the same problem with my Samsung TV.
After about 20 min into a video the subtitles from the second last played video are mixed in that one.
Regards,
Jens
Jens
Yes, exactly the same. It starts ok, and after some time it mixes the subs.
I have no idea how it could be possible. But again and again without logs we are bling. Please follow the instruction at viewtopic.php?f=9&t=556.
I will try to put some logs up this weekend.
Regards,
Jens
Jens
I found this thread through google, I have the exact same problem with my Samsung TV UN50HU6830
Yesterday I played Better.Caul.Saul.s01e01 with an srt file in the same folder, it loads up nicely
Then I played Better.Caul.Saul.s01e02 in a different folder with a different srt file, it played nicely until the 40+ minute. Then the subtitle from the previous ep starts getting mixed in.
Tonight I played an episode of suits (without subtitle in the folder) and BCS Ep2 right after, the subtitle from BCS Ep1 was still getting mixed in.
Debug file attached, many thanks in advance for your help.
- (40.8 KiB) Downloaded 822 times
Hi
Here is mine. Same problem, all is fine till 40 same...
Best regards and waiting for fix.
- (456.06 KiB) Downloaded 685 times
Guys I checked both logs and it seems to me that it is not the UMS problem. UMS sends correctly subtitles to the TV only ones when TV starts to play a movie. There is not a message to send other subtitles when the video is playing. So it seems to be your TV's bug. Or maybe I am wrong
Thanks for the reply. Too bad it's not good news...
I was hoping it was as simple as modifying the video encoder setting.
