Can't get Pin Codes to work (Webinterface)
Hi, first of all i must say that i'm relatively new to UMS. I used PMS, but the server has come a long way since then. Well enough said, let's get to my question
How can i make Pin Codes work in the WebInterface. I have made the "UMS.codes" and put it in "Program Files (x86)\Universal Media Server". Is this the correct folder? And have i made the contents of the file correctly like on "viewtopic.php?f=3&t=2266&p"?
Let's say this is my folder named "Movies" (Lame name I know
), and if i want Pin protection on my folder i enter *.Movies.* in the config file followed by the pin 1234 (example pin). So the file will look like this (without the quotes) "*.Movies.*,1234"
Is this the correct way to make the file and get pin protection?
Hope someone can help me
-FF7OSTLover
PS. I'm using default UMS 5.0.0 setup with Java 8 on Windows 8.1
-FF7OSTLover
