Windows 7 prevent sleep not working as expected
cristidb
Post by cristidb »
Hello, I use UMS 5 on Windows 7 64bit. If Prevent windows from sleep is checked, the computer won't go to sleep at all. I expected this to prevent windows from sleep while streaming.
As a workaround, I disabled the feature and use coffee to prevent sleep while upload speed is at least 128k
http://coffee-sc.sourceforge.net/
cristidb
Re: Windows 7 prevent sleep not working as expected
Post by cristidb »
Since nobody answered on this topic for one month, I fixed it myself. Now UMS prevents windows from sleeping only when streaming.
The problem was in the WinUtils class.
The fix only works when HTTP V2 is unchecked. If I have time, I will look in the HTTP V2 code.
WinUtils.zip
(3.2 KiB) Downloaded 508 times
andycoo
Post by andycoo »
Hi cristidb
Thanks very much for fixing this obvious limitation.
I'm not clear on whether you have committed this change and it's included in a new release, or you attached the file so we can rebuild ourselves.
Please could you clarify?
Andy
cristidb
Post by cristidb »
The fix is not committed. I've only attached the modified class to this topic. Please review the fix and include it in the next build.
