[Solved] No Options in Transcoding Settings
I feel as if I searched on this yet I found nothing, every other screen shows but the most important one.
http://i.imgur.com/yGizA6L.png
I'm sorry but I'll off shoot this I was trying to watch something tonight that I actually had to use a different render for, didn't see VLC in the list on my PS3 so I decided to check it out, turned out I couldn't see my transcoding settings. As you see in the screen shot I just sent, this was after I reinstalled java and UMS.
I don't know the issue I wish I could explain it off hand other than black magic but heres my debug log.
(also I'm 192.168.1.2, default gateway is 192.168.1.1 if it helps any.)
- (20.1 KiB) Downloaded 255 times
Re: No Options in Transcoding Settings
On the General Configuration tab, uncheck "Hide advanced settings"
