filename sorting question capital/small letters
hi All,
Just started using UMS (Windows version) with a Samsung UE55H6500 TV. What I noticed is that viewing the video list, Capital letters always come first before small letters.
Example file order:
ArrowS01E10.avi
CalifornicationS02E07.avi
The.100.S02E11.avi
arrowS01E09.avi
californicationS01E02.avi
What I would like is to treat capital letters and small letters the same, so for example:
arrowS01E09.avi
ArrowS01E10.avi
The.100.S02E11.avi
Is it something that can be solved within UMS, or the TV does this, the files need to be renamed?
thank you in advance!
Edit: found this topic: viewtopic.php?f=5&t=1800 from December where it's said that prettifying will solve it in the next release. I'm using v5, tried prettifying (what i assume is the next version), but it does not work first letters are not capitalized
Example file order:
ArrowS01E10.avi
The.100.S02E11.avi
arrowS01E09.avi
arrowS01E09.avi
ArrowS01E10.avi
The.100.S02E11.avi
