[Solved] xbox one works wireless not wired
I cannot get UMS to show up on my wired network???It will work if i unplug my wired connection to the xbox one and let it be wireless to the network.I do not change any of my network settings.I am using a dd-wrt router.I dont change any of my firewall settings or any router settings just unlug the ethernet cable?any suggestions?I have attached the debug logs i may try to make the static ip address the wireless and see if that works
- ums_dbg2.zip
- (19.79 KiB) Downloaded 278 times
- (28.98 KiB) Downloaded 276 times
Re: xbox one works wireless not wired
Hi johnscrub, are you able to access the Internet via the Xbox if it's wired?
yes i can play muliplayer, but have not tried internet explorer.I have discovered that it is not UMS.I did some checking and xbox doesnt show up at all on anything if its wired.As soon as it wireless;it shows up on all windows computers.Im thinkng it is the router firmware
i put it in dmz on wireless and i thought it was on wired but hell i dont know
Re: [Solved] xbox one works wireless not wired
I had a similar problem to that with Xbox 360 too, anyway thanks for the updates and hopefully Microsoft fixes it
