Streaming problem
canaillou
Streaming problem
Post by canaillou »
Good day all,
I got a problem with UMS! I set it up on my desktop computer (running Windows 8.1) and added my folders in the media library. This computer is connected via LAN to my network.
On my network, I have 1 TV and 2 laptops (WiFi connected, one running windows 7 the other one windows 8.1) and 1 desktop computer (where the server is installed.)
When I browse the media library from computers or TV, everything seems OK, but when I try to watch a movie things get tricky: from TV loading crashes in a few seconds and from the laptops it downloads the movie to a strange folder: C:\Users\xxx\AppData\Local\Microsoft\Windows\INetCache\IE\QEOZ6ZXD. I can then watch the movie but it's not streaming anymore.
Does someone know what I did wrong? Is there a configuration problem? What can I do to solve this VERY ANNOYING problem?
Thanks in advance for your help.
(24.18 KiB) Downloaded 370 times
jj123
Re: Streaming problem
Post by jj123 »
Unfortunately because you set the debug to trace after the issue happened, the logs you provided do not contain any trace data.
Please set the Debug level to TRACE at the start of using UMS (Before the issue occurs). and then repost your logs
