UMS can no longer find PS3
davecessna
Post by davecessna »
I'd like to add to the couple of reports of UMS suddenly not being able to detect any renderers. PS3 media server seems to still work, I have not tried older versions of UMS but that is my next step.
Thanks in advance!
edit: Sorry forgot to clarify, I'm running UMS 5.0.1 on Java 8, Windows 7 x64. I have also tried forcing the adapter, but that hasn't helped.
Re: UMS can no longer find PS3
Please make logs using this version of UMS, it is a build made specifically for debugging this issue: http://www.spirton.com/uploads/UMS/UMS-764ce59.exe
infidel
Post by infidel »
Updated special build for debugging this issue (try also the one above): UMS-1bbfc78.exe.
Sharsamalot
Post by Sharsamalot »
Hi I am also have this problem(PS3 is on IP 192.168.0.2), I also have the same problem with my Galaxy S3 (IP 192.168.0.4),
Thank you
Sharon
(41.43 KiB) Downloaded 332 times
