[Solved] Samsung H6200 Renderer Missing
jrandall1149
Post by jrandall1149 »
Just bought a Samsung H6203. Surprised to not see it listed in the supported Renderers. Any plans to add?
Wolfgan
Re: Samsung H6200 Renderer Missing
Post by Wolfgan »
jrandall1149 wrote:Just bought a Samsung H6203. Surprised to not see it listed in the supported Renderers. Any plans to add?
You may try it by yourself using another Samsung profile as reference, and customizing for the differences. Look at http://www.universalmediaserver.com/faq ... erSupport1
If it works well, just contribute the file back to the forum so devs can include it as supported in upcoming versions.
All Samsung TVs are supported by UMS. We hadn't added explicit support for that model but it should still work, and I've added explicit support for it now to improve support.
Renegade
Re: [Solved] Samsung H6200 Renderer Missing
Post by Renegade »
I have same model UE40H6203AWXXH and i can't watch one .mkv file with FLAC audio.TV support FLAC and i can watch same video with sound on Serviio (sorry for advertisment).On Serviio i set this option: "Downmix to stereo" on Delivery tab->"Transcoding" section.UMS use Samsung-NotCD.conf for mine TV,its ok?
