seeing engine names instead of file names
HT1
Post by HT1 »
hello all,
i see the codec name instead of the file names when i browse my shares with my tv through ums.
The setting to "do not add engine names" is checked.
Prettify filenames is unchecked.
Cache has been reset many times hoping it would help.
When i enter the folder it can go 50/50 if it shows the file name,
but if it does show the file names when i get in, if i go in a sub folder then come back,
more times than i can count it's engine names instead.
Problem happens in v5.0.0 and 5.0.1 with both versions of java 7 32bits and 8 32bits.
attached the trace log file. hope it helps.
(142.69 KiB) Downloaded 572 times
Win 10 64bits
Qnap TS-212 2x3TB WD Red
Sony Bravia MN (my own conf)
Matt
Re: seeing engine names instead of file names
Post by Matt »
I just opened a trouble ticket for this today
https://github.com/UniversalMediaServer ... issues/499
It's been discussed in this thread
viewtopic.php?f=9&t=2963
