Missing things, as with the old PMS
kakemonsteret
Post by kakemonsteret »
I thought I'd try this one out, since PMS has been cancelled and some movies never, ever were possible to play for me.
Now I'm trying to play an MP4 file of the following type (info from the file command):
ISO Media, MPEG v4 system, version 1
And the UMS log gives me this error:
03-09 20:01:51  Loading renderer names from /home/frank/Downloads/ttmmpp/ums-5.0.1/renderers
03-09 20:01:51  Error loading libzen: Unable to load library 'zen': Native library (linux-x86-64/libzen.so) not found in resource path ([file:/home/frank/Downloads/ttmmpp/ums-5.0.1/update.jar, file:/home/frank/Downloads/ttmmpp/ums-5.0.1/ums.jar])
03-09 20:01:51  Loading MediaInfo library
03-09 20:01:51  Error loading MediaInfo library: Unable to load library 'mediainfo': Native library (linux-x86-64/libmediainfo.so) not found in resource path ([file:/home/frank/Downloads/ttmmpp/ums-5.0.1/update.jar, file:/home/frank/Downloads/ttmmpp/ums-5.0.1/ums.jar])
03-09 20:01:51  Make sure you have libmediainfo and libzen installed
Of course, installing libmediainfo0 and libzen0 didn't help at all. This is the error now (and the same might have been there before installing the above libraries too):
Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: Linux/3.13.0-24-generic UPnP/1.0 Cling/2.0
03-09 20:18:23  The server is now available for renderers to find
03-09 20:18:24  No IP filter specified, access granted to /10.0.0.146
03-09 20:18:24  Checking shared folder: /mnt/felles/Media
03-09 20:19:44  External input stream instance is null... stopping process
03-09 20:19:44  There is no inputstream to return for File.2
03-09 20:19:50  External input stream instance is null... stopping process
03-09 20:19:50  There is no inputstream to return for File.2
And the FULL debug log says:
DEBUG 20:19:45.765 [New I/O worker #6] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 20:19:45.813 [cling-5] MediaServer found: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:2f3c0d71-f6be-f861-5eca-e2411cd4a77c, Descriptor: http://10.0.0.111:32469/DeviceDescription.xml, Root: true
DEBUG 20:19:46.265 [New I/O worker #6] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 20:19:46.766 [New I/O worker #6] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 20:19:47.266 [New I/O worker #6] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 20:19:47.767 [New I/O worker #6] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 20:19:48.267 [New I/O worker #6] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 20:19:48.767 [New I/O worker #6] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 20:19:49.268 [New I/O worker #6] External input stream instance is null... sounds not good, waiting 500ms
DEBUG 20:19:49.768 [New I/O worker #6] External input stream instance is null... sounds not good, waiting 500ms
ERROR 20:19:50.269 [Hanging External Process Stopper] External input stream instance is null... stopping process
DEBUG 20:19:50.271 [Hanging External Process Stopper] Stopping Unix process 22009: tsMuxeR-new-18
ERROR 20:19:50.269 [New I/O worker #6] There is no inputstream to return for File
DEBUG 20:19:50.272 [Hanging External Process Stopper] Stopping Unix process 21977: mkfifo-19
DEBUG 20:19:50.273 [Hanging External Process Stopper] Stopping Unix process 21991: mencoder-16
DEBUG 20:19:50.275 [Hanging External Process Stopper] Stopping Unix process 22005: mencoder-17
WARN  20:19:54.653 [Process Destroyer] Sending kill -14 to the Unix process: 21949
DEBUG 20:19:54.660 [Process Destroyer] Successfully sent kill -14 to the Unix process: 21949
WARN  20:19:54.658 [Process Destroyer] Sending kill -14 to the Unix process: 21962
DEBUG 20:19:54.669 [Process Destroyer] Successfully sent kill -14 to the Unix process: 21962
INFO  20:19:56.928 [UPNPHelper] No IP filter specified, access granted to /10.0.0.112
WARN  20:20:00.274 [Process Destroyer] Sending kill -14 to the Unix process: 21991
WARN  20:20:00.276 [Process Destroyer] Sending kill -14 to the Unix process: 22005
DEBUG 20:20:00.282 [Process Destroyer] Successfully sent kill -14 to the Unix process: 21991
DEBUG 20:20:00.287 [Process Destroyer] Successfully sent kill -14 to the Unix process: 22005
DEBUG 20:21:53.487 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 20:21:53.493 [New I/O worker #8] HTTP User-Agent: Linux/3.13.0-24-generic UPnP/1.0 Cling/2.0
DEBUG 20:21:53.498 [New I/O worker #8] HTTP User-Agent: Linux/3.13.0-24-generic UPnP/1.0 Cling/2.0
DEBUG 20:21:54.561 [New I/O worker #2] HTTP User-Agent: UPnP/1.0
Some files I can play, but it seems to be as many unplayable formats here as I had in PMS.
(23.49 KiB) Downloaded 431 times
kakemonsteret
Re: Missing things, as with the old PMS
Ah. I see that the community support here is the exact same as for PMS, also known as absolutely nothing. Uninstalling this piece of shit. Please delete my account on this forum.
I had started to write a reply to help you with the issue until I saw the second post.
