UMS first run setup - how to redo?
alanj
Post by alanj »
I want to completely remove UMS and to restart it and re-run the initial setup questions that I saw the first time I ran it.
Is there a way to do this?
Is there a config / first run file that needs to be removed or a command line setting to force it to do that again?
Any thoughts / suggestions on this.
I'm running the latest OS/X release on an iMAC
Thanks in advance.
alanj
Re: UMS first run setup - how to redo?
Post by alanj »
After some playing discovered that if I geo finder to show the LIBRARY files that it was in:
/Users/name-of-user/Library/Application Support/UMS
removing this directory restarts the config next time I loaded UMS
