[Solved] Embedded subtitle problem
ravisdavis
Post by ravisdavis »
Got a problem playing .mkv files on my PS3. With some movies when I try to watch them - either by streaming or copying to the PS3, the regular file not the transcode option that also shows up, - the embedded subtitles show up. In UMS I have the 'definitely disable subtitles' option checked but the subtitles still appear with some movies. I thought it might be that I updated my PS3 to the latest firmware (4.30) but I cannot find any option to turn subtitles on or off, just change language. I have tried to reinstall UMS 1.60, uncheck and check the disable subtitles option (with saving the configuration) and still no luck.
Is there something simple that I need to do without stripping down the file and remerging without the subtitles? Thanks for any help.
Re: Embedded subtitle problem
Can you please post a debug.log after reproducing the problem?
ravisdavis
This log was after I copied over a file to the PS3, still with subtitles coming up.
debug.log
(660.26 KiB) Downloaded 831 times
Hmm looks like I will need more information. Please reproduce the problem then go to the Traces tab and "Pack debug files" and attach the zip file. Thanks!
ravisdavis
Here is the zip file. Thanks for taking the time.
(48.06 KiB) Downloaded 679 times
Hmm, odd! Can you try this:
1) Rename UMS.conf to UMS1.conf (for a backup), it should be in C:/ProgramData/
2) Download and install the new UMS (2.0.0)
Let me know if that works
ravisdavis
Yup that worked! Something funky going on with 1.60 and my system I guess. I was hesitant to update right away until I found the root of the problem but this works. Thanks again!
Ah great! Thanks for confirming :)
Gareee
Re: [Solved] Embedded subtitle problem
Post by Gareee »
I've been running into this same issue.. subtitles showing up even though definitely disable is selected.
I don't see a c:/programdata folder though to try the fix. (Win 7 64 bit here)
I did try to rename it in the install folder, but the new config that was created adopted the old settings (I could still see all my old folder settings.)
Is the programdata folder possibly elsewhere?
EDIT: Windows hid hidden folders after some system maint a month or so ago.. unhiding them, and following this fix cured the problem.
I've noticed that UMS does not auto decode bluray image files though... is this normal behaviour? (I can play them on my pc, but not off UMS on the ps3.)
Gareee wrote:I've noticed that UMS does not auto decode bluray image files though... is this normal behaviour? (I can play them on my pc, but not off UMS on the ps3.)
Yeah that is normal, I have started working on adding blu-ray support so hopefully it will be done soon
