Subtitles issue while playing 1080p video
elessar
Post by elessar »
Hi.
I'm using UMS for a while but it's still remain a problem that I can't solve. It's about FullHD & subtitles combination. When I'm streaming 1080p with subtitles then video going to horizontally shrink. I just can't handle with it. I tried config options in program but I can't find any solution. Interesting thing is that when I play 1080p without any subtitles or 720p with and without subtitles the video is just fine. Full screen resolution with no issue. The problem exists only in case 1080p with subtitles. Did anybody have same problem? What do I have to do to watch FullHD movies with subtitles?
Wolfgan
Re: Subtitles issue while playing 1080p video
Post by Wolfgan »
You may start posting logs capturing HD file play with and w/o subtitles. Follow this guide viewtopic.php?f=3&t=556
elessar
Post by elessar »
OK, there's a log.
(19.82 KiB) Downloaded 272 times
