VLC not found
VLC not found
UMS does not find VLC although it is installed.
This has been a long standing issue but not critical since I never use it.
I have installed 64 bit VLC 2.1.5
debug.log
- (110.28 KiB) Downloaded 704 times
Re: VLC not found
I had the same problem. I found a solution though. You need to edit the UMS config file manually and add the path to VLC there. Look for the line that begins with vlc_path =
This is line from my config file with the path to vlc added: vlc_path = C:\Program Files\VideoLAN\VLC\vlc.exe
I did that and restarted the server and vlc is now found.
