M3u rtmp sources
patmos
M3u rtmp sources
Post by patmos »
Hi, I can't run this m3u playlist with rtmp sources. Other m3u playlists with http sources work perfectly.
And these are invisible to the renderer for some unknown reasons:
https://mega.co.nz/#!Pg9TjIpL!520wdvpUT ... ffvnHaGg5A
Video just start streaming but it restarts after 3 seconds or pass to next rtmp stream in the playlist.
Any suggestion is welcome, already tried restarting pc, restarting both devices...thank you!!!
If you want to see the full specs of the renderer (mime codecs, dlna, etc), I attach that information here, maybe the problem is that I'm not using the right .config
full specs.txt
Device Spy specs.
(3.58 KiB) Downloaded 341 times
