UMS 5.1.4 unsupported file
Hello all, I'm new to the forum !
Here is the problem I faced yesterday:
I watched a Game of Thrones season 6 finale in the morning (using UMS), then later after system restart I was prompted to update the UMS, so I did.
When I tried to run the episode again, I was told it was 'unsupported file'.
By installing previous and previous versions of UMS (I was away from home for a while so the version I was updating before was older then just 5.1.3) I ended up with version 5.0.0 which plays the file.
Is it something I need to change in settings to play this file with the newest version or is it a longer story ? Cheers !
General
Unique ID : 242542670750321117145977378449801552090 (0xB67804ECD859EE1D9F0CAF7C2F4F20DA)
Complete name : Game.of.Thrones.S05E10.1080p.HDTV.x264-BATV.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 5.96 GiB
Duration : 1h 0mn
Overall bit rate : 14.2 Mbps
Encoded date : UTC 2015-06-15 06:13:00
Writing application : mkvmerge v7.9.0 ('Birds') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
DURATION : 00:58:51.176000000
NUMBER_OF_FRAMES : 661
NUMBER_OF_BYTES : 18930
_STATISTICS_WRITING_APP : mkvmerge v7.9.0 ('Birds') 64bit
_STATISTICS_WRITING_DATE_UTC : 2015-06-15 06:13:00
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 0mn
Bit rate : 13.5 Mbps
Width : 1 920 pixels
Height : 1 078 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.272
Stream size : 5.68 GiB (95%)
Writing library : x264 core 146 r2538 121396c
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
Language : English
Default : Yes
Forced : No
Color range : Limited
Matrix coefficients : BT.709
DURATION : 01:00:11.108000000
NUMBER_OF_FRAMES : 86580
NUMBER_OF_BYTES : 6221634597
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 0mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 165 MiB (3%)
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Default : Yes
Forced : No
Re: UMS 5.1.4 unsupported file
Better include your log files as per viewtopic.php?f=3&t=556
I have the same issue with a ps3. I'll submit a log file in the morning. I had to use transcode ffmpeg aac audio to get it to work. Note the ps4 now supports dlna streaming!
