Version 5.2.1 is released
Post by SubJunk » Sat Jul 11, 2015 4:40 pm
General:
This release fixes MediaInfo, updates the Spanish translation, improves Xbox One thumbnails and more!
Changes since 5.2.0:
  • General:
    • Improved efficiency of configuration file loading (thanks, Nadahar!)
    • Improved support for quotation marks and apostrophes on some renderers (thanks, Nadahar!)
    • Fixed broken 32-bit MediaInfo dependency
  • Renderers:
    • Fixed Xbox One thumbnails
  • Languages:
    • Updated Spanish translation (thanks, AlfredoRamos!)
Whogie
Re: Version 5.2.1 is released
Post by Whogie » Sat Jul 11, 2015 6:18 pm
Sorry to be a broken record, but I'm not sure if you saw my last post in the last thread. Also, pictures.
XB1 still has half rendered thumbnails in this version
http://i.imgur.com/4VXeTZ4.jpg
but adding
ThumbnailBackground = black
makes it work. It looks the same with the background as without
http://i.imgur.com/X5NP2ho.jpg
Post by SubJunk » Sat Jul 11, 2015 6:24 pm
Whogie wrote:Sorry to be a broken record, but I'm not sure if you saw my last post in the last thread. Also, pictures.
but adding
Hmm that's weird, I'll add that line soon but I think it points to a different problem, like maybe the Xbox One doesn't like the image format for that folder image. Does it happen with any other images?
Whogie
Post by Whogie » Sat Jul 11, 2015 6:35 pm
After going through a few folders, video thumbnails seem to render okay. #--TRANSCODE--# icons can break though. I think it doesn't like transparencies.
Paradox
Post by Paradox » Sun Jul 12, 2015 6:00 am
Have you tried removing the ThumbnailSize and ThumbnailBackground options and adding
SendFolderThumbnails = false
instead to the xboxs conf file?
Doing that should mean it just uses whatever the device normally uses for a default folder thumbnail. It can also help speed up folder browsing.
Whogie
Post by Whogie » Sun Jul 12, 2015 6:15 am
Paradox wrote:Have you tried removing the ThumbnailSize and ThumbnailBackground options and adding
That does work, except #--TRANSCODE--# icons still break, so ThumbnailBackground is still needed for UMS's other icons.
It does seem the size options may be unnecessary, it's working fine without those.
Post by SubJunk » Sun Jul 12, 2015 10:23 am
Hmm okay, so maybe we should have a renderer setting to convert PNG images to JPG
Paradox
Post by Paradox » Sun Jul 12, 2015 11:53 am
Try also adding...
ForceJPGThumbnails = true
ThumbnailAsResource = true
Does that help the transcode folder?
Whogie
Post by Whogie » Sun Jul 12, 2015 1:55 pm
JPG doesn't support transparencies, and GIF is very limited in colors especially when dealing with transparencies. If it went JPG, it would have to have a background anyways.
Paradox wrote:Try also adding...
Still gives half-renders
No custom thumbnails load at all. It's all system icons. Nothing from UMS or video file previews.
xinseo
Post by xinseo » Sun Jul 12, 2015 8:46 pm
Still can't play most MKV anime BUT we're getting there!
Here is media info of two of them. One is BD rip, other is TV rip.
http://s25.postimg.org/oipsqmmzz/screenshot.png
http://s25.postimg.org/l0dsu8m3z/screenshot.png
