2.1.0 Won't start up.
futurealbert
Post by futurealbert »
As the title says really. Updated not too long ago, program doesn't launch.
Running windows 7 x64. 2.0.0 Worked fine for me. If you need any info from me, just let me know.
Thanks.
Wonderful program.
BoDoP
Re: 2.1.0 Won't start up.
Post by BoDoP »
Same Issue as above.
2.0.0 works fine after re-install
Tried install 2.1.0 as Admin and run as Admin. No go.
SharkHunter
Post by SharkHunter »
First try finding the debug.log file (it's found in the install dir normally C:\Program Files\UniversalMediaServer or C:\Program Files (x86)\UniversalMediaServer).
Secondly how much memory did you give UMS when you installed it? Default is 768 Mb but perhaps you need a lower setting. Run the insall program again and lower the value.
BoDoP
Post by BoDoP »
Tried 512 and 1500 for memory.
There are no entries in the debug.log file at all updated by trying to launch 2.1.0.
Time stamp on debug.log file does not even change when installing and then launching 2.1.0
Installed on two other Win 7 x64 one a fresh install and the other an update. No Problems!
On problem PC
Completely uninstalled, deleted, cleaned registry, disabled AV and Anti-Malware, reboot.
Fresh install same issue.
PC:
Windows 7 Ultimate
Name Windows 7 Ultimate x64 Service Pack 1
Features Terminal Services in Remote Admin Mode, 64 Bit Edition, Multiprocessor Free, OEM-Version
Edition Type Ultimate
HTPC (Gigabyte Technology Co., Ltd. GA-890GPA-UD3H)
Summary
Number of Physical Processors 1
Number of Cores per Processor 6
Number of Logical Processors 6
CPU #1 AMD Phenom II X6 1100T
CPU Name AMD Phenom(tm) II X6 1100T Processor
CPU Code Name Thuban
Vendor AuthenticAMD
Number of Bits 64
Instruction Set MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, NX, VMX, SVM
Platform Name Socket AM3 (938)
Revision PH-E0
Technology 45 nm
Original Clock 3300 MHz
Original System Clock 200 MHz
Original Multiplier 16.5
CPU Clock 3300 MHz
System Clock 197.5 MHz
HT Link 1974.9 MHz
Number of Cores 6
Memory 8190 MB Total, 5234 MB Free
Memory Load 36%
Virtual Memory 16378 MB Total, 13086 MB Free
MetalHead-666
Post by MetalHead-666 »
Got the same issue here.
When I install 2.1.0 and look at the taskmanager java starts but a second later it's not there anymore.
When I do a reinstall of 2.0.0 it works great.
Seems something is not working good in 2.1.0
I am running Windows 7 x86 SP1 with the latest patches
If someone can upload their debug.log that would be great
futurealbert
Feeling a bit under the weather sorry, here is my debug.log. Not sure how helpful it will be. I tried removing it to make a new one by starting up UMS, but nothing was created so enjoy this big one. Might have traces of 2.0.0 in there from messing with installs.
debug.log
(63.4 KiB) Downloaded 921 times
Thanks, futurealbert, but like you said that is only for 2.0.0.
If it doesn't get made in the installation directory, it is probably in: C:\Users\YourUsername\AppData\Local\Temp\debug.log
archy141
Post by archy141 »
Same as the rest running Win7 sp1 x64.
2.10 messes the whole OS up - e.g selecting empty on Recycle Bin would do nothing.
Back to 2.0.0 for now. Thanks for all your hard work.
futurealbert
Strangely no debug.log is getting created in my temp directory.
