Problem with DTS, have only noise
Hi all
I have installed the latest version of ums, 5.2.1, and I have problems with playing movies which have a dts-track. I am using ums since last year and before for years the pms up to version 1.9.2. in the past i could play dts-tracks without any problems as multichannel-track over my ps3.
but since 2 or 3 moths i can't play dts anymore and i am getting an nerving noise signal which is useless. my ps3 is connceted via hdmi to my denon avr x7200 receiver and the ums is installed on my windows 7 computer.
in ums i have deselcted the transcoding options "keep dts tracks" and also encodes audio passthrough for ac3 and dts". under general settings i have set as default renderer the playstation 3 profile.
on my ps3 is the latest firmware installed and under music/sound setting is set the quality to 48 kHz and use this since years. the ps3 is connected over my netgear router directly by wire.
actually i don't have any idea how to get the dts tracks working again and that's your kind support is highly apreciated.
i am looking forward to hear from you and thank you very much.
sincerely thydney1970
