PS3 - ffmpeg.exe has a return code of 1!
Moving this from the Announcements Board under the 2.1.1 release.
This is something I've encountered since first using 2.0.0. But even with 2.0 I'd occasionally get something to play, now nothing seems to.
I get this ffmpeg error almost every time I try to view something;
And the folders on the PS3 screen act funny once the folder limit is hit and the "folder limit" folder is used.
Can you please have a look at the logs and see if you can make out anything? I'm at a loss.
ffmpeg.exe has a return code of 1! Maybe an error occured...
- ums_dbg-ffmpeg-2012-11-25.zip
- (304.88 KiB) Downloaded 552 times
,____
||_|__\\__
|(0)___(o)|
||_|__\\__
|(0)___(o)|
Re: PS3 - ffmpeg.exe has a return code of 1!
Any thoughts?
After reading some recent posts for the Jumpy plugin I'm starting to think it's similar to the buffering issue mrkrabs is seeing: viewtopic.php?f=6&t=288&start=30
,____
||_|__\\__
|(0)___(o)|
||_|__\\__
|(0)___(o)|
Something similar happens to me:
viewtopic.php?f=6&t=288&p=2649#p2649
any idea of a possible solution??
