Some issues after upgrading to Win10
Hi
So I never had this issue on any of my Win 7 installs in the past 7 or so years since 7 got released.
But after upgrading to Win 10, half the settings in UMS are missing.
After the upgrade process I did a clean install of Win10 and ever since, this happens...
I can't make any changes because none of them appear.
I have the latest java installed both 32 and 64 bit and latest UMS installed too.
I just reinstalled both and still same issue.
Never had this happen on Win7.
Is there anything that can be done?
Thanks.
Thanks.
Re: Some issues after upgrading to Win10
First screen --> Hide Advanced Options
-_-
are you serious...
I've never ticked that.. and it was never ticked by default...
whhyyyyyyyy
Now I feel stupid.
Thank you sir. Hats off to you.
are you serious...
whhyyyyyyyy
Now I feel stupid.
It is by default enabled to not confuse general user with advanced, hardly understandable options
In my opinion I should enable advanced options by default so users will not loose great configuration options which are hidden by default. For users which are confused, they can hide them again.
Btw. you enabled it to shown
Installer asks you at the end of the installation if advanced options should be hidden or not. By default it is ticked
