Samsung BD-H6500 BR/DVD Player
So,
I just recently replaced my PS3 with this player (had to move PS3 to basement)
I've got a library of ripped DVD's in .ts format that will not play on the player - well they play, but only for a few seconds, and the audio is -way- off. After a few seconds, it will start playing the next movie on the list... (with same results)
Any assistance here? (also the thumbnails look terrible compared to the PS3 and my Sammy TV)
Attached is the media info a movie that is typical in my collection (all ripped the same way)
Format : MPEG-TS
File size : 5.53 GiB
Duration : 2h 14mn
Overall bit rate mode : Variable
Overall bit rate : 5 899 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Codec ID : 2
Duration : 2h 14mn
Bit rate mode : Variable
Bit rate : 5 155 Kbps
Maximum bit rate : 9 800 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : 2:3 Pulldown
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.622
Time code of first frame : 00:59:58;10
Time code source : Group of pictures header
Stream size : 4.83 GiB (87%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 129
Duration : 2h 14mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 430 MiB (8%)
Text
ID : 4113 (0x1011)-CC3
Menu ID : 1 (0x1)
Format : EIA-608
Muxing mode, more info : Muxed in Video #1
Duration : 2h 14mn
Stream size : 0.00 Byte (0%)
Re: Samsung BD-H6500 BR/DVD Player
Also, if this container is not the best (transport stream) What would your recommended re-encoding method be for these files? (and continue to work on PS3 as well)
while .ts format is supported by most of Samsung blu ray players. But according to your situation you are not able to run that format easily. Thus, try to install TSmuxer as it convert it to BR file structure to burn and play as a BR disk. It will not re-encode,just make it BR compatible. Or check Samsung Bd-h6500 Manual for more options and troubleshooting steps. Hope this might help you.
