How to disable transcoding?
Versions of UMS past 5.1.0 no longer work correctly with my Samung TV. Every file shows up with a video engine. My TV can play all these files natively, and works fine if i go into the transcode folder and pick "no encoding". How do disable this?
Note: "Skip transcoding for the following extensions" does not work, it works on a handful of files and the setting is not respected for others.
Re: How to disable transcoding?
Also looking to disable this option at all transcoding the video, someone help ?
If you got MediaInfo = true
Try add:
Try add:
Supported = f:mpegps|mpegts m:video/mpeg
Supported = f:avi|divx m:video/x-divx
Supported = f:mp4 m:video/mp4
Supported = f:wmv m:video/x-ms-wmv
Supported = f:mkv m:video/x-matroska
Supported = f:avi m:video/avi
Supported = f:mov m:video/quicktime
Supported = f:flv m:video/x-flv
In the next version (6.5.2) it will be possible to disable transcoding completely by setting this in UMS.conf:
Disabling of transcoding per extension has also been fixed.
disable_transcoding = true
