avi transcode issue
nocciola82
avi transcode issue
Post by nocciola82 »
hi all
first: sorry for my "not perfect" english :oops:
second: I use UMS from the first version with great satisfaction, so THANK YOU VERY MUCH
my configuration:
PC with dual core duo, win 7 home premium, wired connection with TV Sony EX500
I use tsMuxeR engine as default, Mencoder as a second one; the other engines are deselected.
from 2.00 version of UMS I can not directly see the .avi files, I must access in the folder "transcode" and select the file, so it works fine, then Mencoder is ok.
how can I see the avi file directly without going through the "transcode" folder, like the earlier UMS versions?
I hope I have been explicit.
Thanks.
Re: avi transcode issue
Does this still happen with 2.2.2?
