Sound stops
Sound stops
I've tried the latest 2.1.2 build but with that one, the audio just drops after a while.. I also had it with some other movies, but with this one I immediatly grabbed the debuglogs and posted them.. Hope you can fix it.. Running PMS SB71 to continue to watch the movie..
PS3 with Rebug 3.55 CFW..
- ums_dbg_grabbers lost sound.zip
- (6.85 KiB) Downloaded 585 times
Re: Sound stops
I notice the sound just stops after awhile as well, if I stop the movie and then press play again the sound will return.
I was using txmuxer,
this has never happened to me before and i just recently upgraded to 2.1.2
added my logs in case it helps
thanks
thanks
- (45.37 KiB) Downloaded 584 times
Re: Sound stops
I can't see any problems in the logs. SuperDre, you mentioned that PMS SB71 fixes it, can you try taking mencoder.exe from that version and pasting it into UMS to see if that is the problem?
Re: Sound stops
I have to sadly say I first tested the scene from another movie which had problems back then, but this time it played through, so it might be something with a buffer or it might even be fixed while you didn't even know it.. So I have to get back to you on this when it happens again with a newer version, will stay on the superdreversion you posted in the other thread until a new official release.. so sorry..
